Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
Having a problem turning it on
I recently had my Denali stolen and the thieves manage to mess up my whole ignition really badly … now my key don’t fully turn all the way and the only way to turn it on is by hitting a relay on the fuse box is there any solution to my problem …?
Add a comment
1 Answer
Most Helpful Answer
Most likely one of three possibilities. Attached to the actually key switch are two small usually light green switches, one may have gotten broken moved etc during the theft.
2: that particular relay has sticky contactors inside and needs to be replaced.
3: inside the steering colum cover at the ignition switch and gear shifter there is a stop the prevents the key from being turned to the run position if the shifter is not completely in the park position. I could have gotten bent or mis aligned during the theft.
Score 1
Add a comment
Add your answer
El gallo chingon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 388
