Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
right trigger begun to squeak / help pls
my right trigger started squeaking is there is anyway to remove the squeaking without disassembling the controller ?
Score 2
Add a comment
Most Helpful Answer
I had the same problem with my controller but it turns out to squeaking is from the spring in the trigger all I did was hold the trigger down and the spring should be exposed and then just move it to the side with a needle and that should fix the problem
Score 3
4 Comments:
Which side of the trigger?
by
Thanks,this worked!Even though it still seems to be out of place compared to the other trigger the sqeaking is gone.
by
@no170846 on the right side of the trigger you should see the spring exposed,it should still be visible a little bit anyway,the left side is covered with plastic anyway
by
Thank you so much! I managed to do exactly what you said and worked!
I've had previously put some graphite power on the trigger and it worked for a while, but the squeaking had returned.
by
Add a comment
unfortunately, no
the only way it could be without disassembling is if something is stuck in it.
you should check for liquid/semisolid damage (squeaking probably means food grease, butter, ect. got in the trigger)
https://www.ifixit.com/Guide/DualSense+C...
however, is your controller under warranty?
also many people are complaining of issues with the triggers on this controller, so i would expect a recall of some sort, but i would still try to fix it in case
Score 1
3 Comments:
if there are any food grease in the trigger can i clean / remove it without disassembling as well ?
also yes my controller is still under warrenty does it cover the squeaking ?
by
you could if you have a small enough item that could clean out the grease
but if that doesn't work, i would go the warranty route
by
thank you so much for this comment, all i did was hold down the trigger and blow into it and that seems to have removed whatever was stuck in it and it removed the squeaking.
by
Add a comment
It’s probably the spring that’s the issue. Use some WD-40…works like a charm.
2 Comments:
It's probably just out of place like Juan's comment said,i would advise trying that first before using WD-40
by
I did that and my trigger stopped working altogether.. Use caution when doing that. I took it apart to try to clean the contact point of the pressure sensor but to no avail.
by
Add a comment
blow and hold down trigger on non-mouse click triggers, otherwise, no idea
Add a comment
my problem was with my left trigger i moved the spring and tried to bend it slightly with a knife like the other comment says but i used some super lube it’s a multi purpose synthetic grease and it’s dielectric and now it’s so smooth and i used a little of it for my thumb sticks and they are soooooooo smooth now
1 Comment:
you can try this by just taking the bumpers off or you can take the two halves apart like i did to make it easier
by
Add a comment
Add your answer
Jack bale will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 206
All Time: 30,890
