The sixth generation of Ford's Falcon line, including the AU, BA and BF series.
Where is oil leak from
How to find where oil leaking from engine is
Add a comment
1 Answer
Use a flashlight to check underneath your car and around your engine – telltale drips might lead you right to the problem. There are several common locations for oil leaks in your car, including: At your oil pan gasket. At your oil filter or drain plug
Add a comment
Add your answer
rob hutchings will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 50
All Time: 439
