The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
WhatsApp calls with Bluetooth headset
When I'm using a Bluetooth Headset and I make a WhatsApp call, my friend will stop hearing me as soon as the screen of my phone goes on standby. Have you experienced that before and what can I do.
Add a comment
1 Answer
Most Helpful Answer
Set the screen to either stay on longer or not turn off. Be warned, depending on phone you could be causing screen burn by doing it. When the screen goes off it basically closes the app, ending the call so to speak. There may be something in permissions you can change.
Score 2
1 Comment:
Thank you for your response, that is what i currently do, however, you should note that this is not good for the battery and it can also burn the screen. I will appreciate if anyone knows the permission that can be activated or changed.
Thank you Nigel
by
Add a comment
Add your answer
Kunle Olagunju will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 236
