Android phone from Huawei, released December 2014.
Scratched battery foil during removal
I scratched my phone battery foil as I was tryi6to remove. After fixing the phone and fixed back the battery, turn on the phone. The battery started draining fast. How do I fix the battery to hold char
Score 1
Add a comment
1 Answer
@samken "How do I fix the battery to hold char" you do not. You replace it. It is absolutely possible that you have received a bad battery. Replace it once more from a different seller and re-evaluate. You also want to make sure that you have your power saving mode on, and your apps and network settings reflect those as well.
2 Comments:
Ok thanks, I will have to replace it then with a new battery
by
@samken It's the safest thing to do. Best of luck.
by
Add a comment
Add your answer
Samuel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 34
All Time: 237
