Repair and troubleshooting information for the Kushlan 350DD, an electric wheelbarrow-style cement mixer.
Barrel not spinning or frozen.
After storing for a few months, I flip the switch, and it is making a humming noise. However, the barrel does not spin, I cannot spin it manually before I take it apart, I was wondering if anyone had experienced the barrel, frozen or not spinning. I did check in the breaker button is not tripped.
Score 1
Add a comment
1 Answer
Most Helpful Answer
There should be a large capacitor on the motor. That could of gone over time. Most mixers are ran on a worm drive gearbox so you can't rotate the drum by hand. Is there any way to safely rotate the drive mechanism? It could be jammed with sitting.
Score 3
2 Comments:
After testing, it appears to be a dead capacitor. Thank You!
by
@Joseph Galaska No problem, hope you get it working.
by
Add a comment
Add your answer
Joseph Galaska will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,145
