Up to 20% off select tools
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
Access Time Capsule files from Linux
Hi iFixers đź‘‹
I've been looking into this for years and still can't find a solution: has anyone maybe finally managed to access TimeCapsule files from Linux?
I've been all over the internet many times and tried over AFP and SMB - it still shows some weird error and nothing happens 🤷
Score 3
1 Comment:
I actually found this today:
https://askubuntu.com/questions/1094087/...
Will give it a try and let you guys know if it works.
Not really the most effortless approach, but whatever works
by Share
Add a comment
1 Answer
Are you able to access it using a Mac system?
4 Comments:
Hi, sure, on anything other than Linux it works just fine.
by Share
@insympathy
Just wondering if this would help depending on what type of file system is used by the files on the Time Capsule
by Share
Hi 👋🏻 thanks for sharing, bit the system used is not yet APFS - it’s HFS+ and even that doesn’t really matter because I’m mounting it as a network resource and not directly as a physical device, that’s why my only options are AFP and SMB protocols
by Share
@insympathy - SMB is a bit of a wacky of a protocol as it can sit on top of NETBIOS or over UDP as well as TCP! MicroSoft also altered its implementation as well as it’s Port assignment.
Here’s a useful backgrounder IBM - Red Hat SMC Protocol
I would setup an Ethereal sniffer to monitor the dialog so see what’s happing on the wire. Here’s a good writeup SMC-R Interpretation Series – Part 1 and SMC-R Interpretation Series – Part 2
It’s been years since I’ve worked on SMC, I just don’t remember what Apple did and clearly this is a dead product offering so they won’t be updating it.
by Share
Add a comment
Add your answer
in_sympathy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 41
All Time: 1,799
