The Chevrolet Express and its mechanically identical twin GMC Savana are Full-size vans from General Motors. They replaced the Chevrolet Van and GMC Vandura in 1995.
Transmission has no up shift
No up shift from second gear
1 Comment:
Hi,
What is the year model of the vehicle?
by
Add a comment
1 Answer
Is it an automatic? Most likely it's the Auto Trans Computer. A common problem throughout the 1990's built models. I've personally repaired thousands. Problem often starts with electrolytic capacitors and you can smell it. Leaking / exploding ones often pop the uP chip. Can also be the sensor, but you will need to measure to see if it's switching.
Add a comment
Add your answer
marwanyasin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 497
