Up to 20% off select tools
Third generation Surface Pro tablet, released June 20, 2014.
Touch screen not working.
The touch screen isn't working. I purchased a Surface Pro with a bad battery and broken screen. Touch screen was working initially before screen replacement. I've tried two different screens so it doesn't seem to be a hardware issue. All of the drivers appear to be installed properly. I ran the hardware check and everything passed except the touch screen. Is there something I could've broken when replacing the screen and battery?
Add a comment
1 Answer
There could be missing components from the tablet's board, are you able to look closely around the display connectors to look for any missing parts?
1 Comment:
I don't see any missing parts. I connected everything that I disconnected when removing the original screen. Both ribbon cables are connected properly to the panel and the board.
by Share
Add a comment
Add your answer
Zac will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 320
