The 8" Amazon Fire HD eighth generation model was released in 2018.
How to fix charging port
Charging port needs repair
Score 1
Add a comment
Most Helpful Answer
they are usually replaced using hot air, a soldering iron, solder and flux
Score 1
2 Comments:
Thanks for your answer but I really need step by step instructions on how to carry out the replacement. What tools I will need and stuff like that as well.
by
@johncam you would need a soldering iron with a small tip, a hot air station, flux and solder. https://www.youtube.com/watch?v=RlwB1Itz...
by
Add a comment
If you don't have any experience (micro)soldering your best bet would be to find a replacement part if it isnt soldered on to the motherboard, if it is, you probably want to take it to a repair shop... Soldering a USB port with no experience is no easy job
Add a comment
Add your answer
John Campbell will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 596
