The HP Pavilion 14m-cd0005dx is a touchscreen laptop designed by HP. It is 14.0-inches diagonal, with a 1366x768-pixel resolution display.
Guidance on Screen replacement
How much more difficult does “touch screen” function make replacement? Are there many more caveats to screen replacement?
Add a comment
1 Answer
Most Helpful Answer
@eeandersen it is not much more difficult. You will just have a few more cables and connectors. Essentially the same work. You can download the maintenance and service guide for the HP Pavilion x360 14m-cd0005dx from here It'll guide you through the repair
Score 1
1 Comment:
@eeandersen, On your laptop the touch screen function is integrated into the LCD display, so there isn't any separate part to deal with; in fact, you can't replace them separately. As @oldturkey03 mentioned, there will be one more connector to route and plug in for the digitizer, but that's it for the difference between replacing your display and a simple LCD replacement.
by
Add a comment
Add your answer
Eric Andersen will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 24
All Time: 323
