The N200 5G is a OnePlus entry-level phone. It sports a 6.49” (1080 x 2400) screen at a 90hz refresh rate, 64 GB of internal storage, expandable storage up to 256 GB, and 4 GB of RAM.
How do I replace just the front glass?
Out of all the videos I've seen, most just get a full lcd replacement. I don't want to replace that, I just want to replace the screen glass.
Add a comment
Most Helpful Answer
Hi Lily,
The problem here is that the LCD and front glass are bonded together with a glue called OCA, or Optically Clear Adhesive. It generally requires specialized tools, equipment and experience to separate them successfully, and then rebond the new glass to the old LCD. In almost all cases it's not worth the time and effort it takes to do that; in order to make sure you don't get bubbles in the glue you need to cure it in a vacuum chamber, which most of us don't have at home.
Since the replacement display sells for under $25 USD on AliExpress, it's really not worth your time to mess with separating the glass, cleaning the LCD, ordering the correct OCA and then trying to get it reglued without bubbles. I strongly recommend you just bite the bullet and replace the whole thing.
Score 3
Add a comment
Mi pantalla está roto
2 Comments:
For those of us who don't speak Spanish, Google says this means:
My screen is broken
by
Hi Yanick,
Assuming you're coming here for help in repairing your screen, even though iFixit doesn't have any information on your phone, that doesn't mean we can't be of assistance.
This same repair has been addressed on here previously; see the following post for information on replacement parts and instructions.
Need a new screen
by
Add a comment
Add your answer
Lily Mung will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 41
All Time: 1,092
