The first-generation Volkswagen Touareg was released in 2002 and was produced until 2010.
Rough idle reason causes
Add a comment
1 Answer
Most Helpful Answer
Hi Aweston,
That's a pretty generic question; you'll be much more likely to get a relevant answer if you can include more information, such as,
  • What year, engine and transmission do you have?
  • When did the rough idle start? Has anything changed with the car around the time the problem started?
  • Does it idle rough all the time, or is it different when it's warm or cold?
  • Is the check engine light on?
  • Have you pulled the OBD-II codes? If so, what did you find?
Score 1
Add a comment
Add your answer
Aweston will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 22
All Time: 450
