Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Drive problems works externally not internally
It runs a standard 1.5tb hd just fine and I can boot from my ssd in an external case but when I put it into The MacBook Pro it will not boot strange
Add a comment
1 Answer
Most Helpful Answer
I would still replace the HD cable as SSDs run harder so a weak cable often shows up under it Vs a HDD.
Did you select it as your boot drive?
Score 1
2 Comments:
Yes I replaced the cable from Amazon and still no luck, but the same SSD will boot fine from a USB enclosure
by
@Terry Genereaux - Did you check the startup drive within prefs? Also did you install the same OS version your HDD has?
by
Add a comment
Add your answer
Terry Genereaux will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 223
