Repair guides, disassembly, and troubleshooting information for the 7th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in September 2019. Identified by model number A2197.
How to repalce charging port?
the charging port is broken. it was finiky and only charged sometimes or when the cable was held at certain angles, but now it wont charge at all
Score 3
Add a comment
1 Answer
Most Helpful Answer
The charge port on nearly all iPads is a job that will need soldering know how to complete. If you have the gear and know how for that it's a fairly straight forward repair.
You'll need to follow the Logic Board replacement guide to get the board out. All the solder points for the charge port assembly are on the back of the board, underneath a sticker.
If you are not a skilled solderer, I might leave this one to the pros, but any good shop with a board repair tech on staff should be able to handle this.
Score 4
Add a comment
Add your answer
Garreth Meyer will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 100
All Time: 5,774
