A portable and water resistant outdoor speaker designed by Bose for uniform coverage from any angle. Bluetooth, voice commands and auxiliary connections allow multiple connections options for up to 12 hours of use. A lightweight version of the Bose Soundlink Revolve+.
Flat ribbon cable is broken
Is there a possibility to get the ribbon cable between lower circuit board and top circuit board as a spare part?
Score 1
1 Comment
Did you find one as I'm after one too
by
Add a comment
1 Answer
Chosen Solution
I found this. Search for "30-Pin FFC/FPC Flexible Flat Ribbon Cable Pitch 0.5-1mm 6/10/15/20/25/30/40cm" on eBay.
I ordered the 0.5mm pitch, 25cm long. I get 5 for $1.40. I haven't got it yet. Let me guess, you dropped yours and split the cable?
4 Comments:
I noticed your original post was for the Revolve (Non-Plus) . Mine was for the Revolve Plus. You can probably find what you need on eBay.
by
Unfortunately, I have not found one yet. Apparently there are not as a spare part.
by
Hans, did you read the part number off the cable. This place on eBay will make custom ribbon cables. Just figure out how many pins it is and what length you need. It is probably 0.5 pitch.
by
It’s 32 pin, 0.5 mm for soundlink revolve plus.
by
Add a comment
Add your answer
Hans will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 48
All Time: 1,018
