Samsung UN85Au800 dark screen
I bought a UN85au8000 a little over a year ago. About 2 months after I got it, the left side of the screen went dark as though the backlighting turned off. It wasn't THAT much of an inconvenience so I just let it go. But yesterday the right side went dark too.
But then later in the day the left side lit back up. While the right side stayed dark, then the middle also went dark. Left side still good. The right side kind of flickers once in a while. I'm assuming that the backlighting itself doesn't need to be replaced since the left side came back on and the right side still flickers.
I know this is a relatively common issue, but I've never seen anyone say they've had the exact same thing happen as I have. I.e one side being off, then coming back on again eventually while the other 2/3 of the screen go "off" all in one day. Any suggestions?
5 Comments
I see you posted this a little over a month ago. Did you ever figure this out? I have a dark vertical bar in the middle area of the tv and can’t find useful info on how to repair.
by Shawn Tucker
@tucktuck131 what make and model is your TV? What have you checked?
by oldturkey03
I’ve only run the setting’s diagnostic test which didn’t detect anything.
by Shawn Tucker
I ordered a new Power supply Board and a main control board, Fedex sucks, so I'm still waiting to receive the parts, but I'll update once I actually receive them, and get them installed.
by Vaughn
I have a overheating TV which causes the LED strips to fail.
by declan rawlins
