Up to 20% off select tools
Huawei's 2017 flagship smartphone. Released in March 2017. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers VTR-L09, VTR-L29, VTR-AL00, VTR-TL00.
Problems with Bluetooth audio
Since I replaced the display, the Bluetooth has been malfunctioning. When I put on the Bluetooth headphones, the device connects, but there is no sound. I would like to ask if this has ever happened to you and which component needs to be replaced. Thank you
Add a comment
1 Answer
If Bluetooth is turned on and the driver is up to date but your device still doesn't work, try removing the device and re-pairing it. Here's how: Go to Start , enter Devices, select Bluetooth and other devices settings > select the device > Remove device > Yes. Try pairing again.
Regards,
Will
Add a comment
Add your answer
Massimo Piras will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 279
