Up to 20% off select tools
The Meeting Owl Pro is a 360-degree camera, microphone, and speaker system made for collaborative conference calls.
How to replace camera
I have an Owl Meeting Pro that fell off the table and now the camera is broken. The top dome appears undamaged but something in it is broken. The camera picture is mostly blurred/black. Its this something that can be repaired?
Score 10
Add a comment
1 Answer
Most Helpful Answer
Hi Caroline. I know its been a while and my answer will probably not be helpful to you at this point. When the Owl webcam falls off (because most of its weight is in the top, so it is easy to tumble), it often breaks inside the lens. The fisheye lens is built like a cone or a mushroom and it will break where the lens comes inside the cone to each the camera sensor.
That being said, there is no replacement lens available (well, at least not documented). The only workaround is to find a donor webcam from which you will get the lens (and the camera sensor if needed) and "transplant" it to the webcam you are trying to salvage.
Score 1
Add a comment
Add your answer
caroline work will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 64
All Time: 1,931
