Up to 20% off select tools
Repair guides, disassembly, and troubleshooting information for the 5th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in March 2017. Identified by model number A1822. Features a 9.7" Retina display and 64-bit A9 processor.
Home button ribbon flex
Hi all
In need of some help, I stupidly pulled apart the flex on the home button on this iPad 5th generation A1822, and need this to work again, can this be repaired, pictures attached.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Looks like you ripped the cable. Luckily you can use the iPad 5 Wi-Fi Home Button Assembly Replacement guide and replace it. Since this is an iPad with a physical button replacing it will only loose Touch ID but the regular home button functionality remains.
Score 1
Add a comment
Add your answer
colin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 31
All Time: 371
