The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
Is it re-usable to repair multiple devices?
Will it only have a couple uses or will it have as many uses just have to re-micro wave it?
Add a comment
1 Answer
Most Helpful Answer
Hi Carlos,
The iOpener is pretty much infinitely reusable; there's really nothing to wear out in it. All you're doing is heating the gel inside, which heat is then transferred to the phone or device that you're working on. Once it cools off, all you have to do is reheat it for another use. The instructions tell you to give it a cooling off period after a couple of uses to ensure you don't overheat it, but other than that you can use it just as much as your heart desires. As long as it retains its liquid inside, it will still be usable.
Score 4
2 Comments:
Okay got it thanks for the insight! Thats what I needed to know.
by
@charlyz You're very welcome, glad to help! Good luck with your repairs.
by
Add a comment
Add your answer
Carlos will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 42
All Time: 511
