Up to 20% off select tools
The Alienware 17 R4 (17.3 inches) is a gaming laptop, released by Dell in 2016. (AW17R4-7000SLV-PUS)
How do I replace the keyboard?
the title says it all
Score 1
Add a comment
Most Helpful Answer
Hi ALXander47,
Try this guide; it looks like it has all the information you need.
Dell Alienware 17 R4 (P12S001) Keyboard How-To Video Tutorials
Good luck; let us know how it goes!
Score 1
Add a comment
Normally, as I do not have experience with this model, in the process of opening it up, the KBD comes off. If you look on the bottom, there may be screw holes marked with a KBD symbol. Removing those screws will allow you to lift the KBD and remove the cable from the connector on the motherboard.
If there are no such marked screws, you will have to do a little more disassembly.
Add a comment
Add your answer
ALXander47 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 841
