Up to 20% off select tools
Repair guides and support for small electric personal space heaters.
unmarked component identification help
what is it?
measures 119.8v ac on both sides.....
comes off of the board here:
its normal path from pcb ... usually mounted behind the fan....
wtf?
Add a comment
1 Answer
Chosen Solution
That would be a thermistor; basically a resistor whose value changes based on temperature, used to regulate the heat output. Here's a page from DigiKey showing the wide variety of values available.
Glass Encapsulated Diode - Amphenol
Score 2
1 Comment:
that explains its presence at the fan intake. thank you
by Share
Add a comment
Add your answer
agnawn uh mous will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 287
