A 5.5-inch smartphone by Oppo, released in August 2016. Includes a non-removable 3075 mAh battery and a 16-megapixel selfie camera. Model A1601.
Black spot on the bottom corner
My Mobile f11pro . The display was a bit loose a while ago.there are no cracks or damages on the screen.I gave my phone to a repair shop so they can apply glue and fix the loose screen but ever since that this black spot appeared on my screen. Was it caused because of glue getting between the screen or is it some other reason? my phone was not dropped down or hit anywhere as well. please help
Score 1
1 Comment
I can see the screen rotating icon below that black spot. Does it prove that my display is not damaged but it is the glue that may have got in between ??
by
Add a comment
1 Answer
Most Helpful Answer
Could be glue or could be dust or a moisture spot. Unfortunately you're stuck with it unless you're willing to open the phone or have the shop look at it which will cost money. Any pictures?
Score 1
2 Comments:
Yea I have pic how can I upload it here
by
@geraltrivia you must add the pictures to your question. Go to edit and use this guide for that Adding images to an existing question
by
Add a comment
Add your answer
Geralt Liston will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 53
All Time: 1,079
