The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
Graphics Glitch while Gaming
Every time I try to game on it, It glitches out on the graphics and displays weird things and a Factory Reset only fixes it for a few days, It has been needing a battery replacement for years as it dies in under 2 hours but would that cause this?
Add a comment
1 Answer
Most Helpful Answer
Hi @xkienholz,
Does it do this if the charger is connected?
Try starting and using the tablet in safe mode and check if it happens.
If it doesn't then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
Score 1
1 Comment:
I don't use it unplugged from the charger much anymore due to the battery practically being toast, Ill try it out but thank you!
by
Add a comment
Add your answer
Xavier K will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 126
