Up to 20% off select tools
The most advanced robotic vacuum from Ecovacs. With two versions the whole design revolves around either a sensor or camera at the front of the robot to avoid common household objects like socks, cables, weird chair legs, etc. The robot has the option to empty itself with a self emptying bin (Sold Separately).
How to replace the battery
My battery is broken, i want to replace it with a new one, but i don't know where to find the battery. Can someone help me?
Add a comment
1 Answer
Chosen Solution
Hi,
Not sure if you mean that you can't find a replacement battery or whether you don't know where the battery is located in the vacuum cleaner.
Here's a teardown video that may help.
Between 4:31 - 4:33 minutes into the video the battery is seen being disconnected/removed from the vacuum cleaner.
Usually the battery model or type number information is printed on the battery itself.
Search online using that information to find suppliers that suit you best.
Score 6
Add a comment
Add your answer
Dennis Hendriks will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 72
All Time: 4,932
