The Black N Decker Toast R Oven TRO200 is a 4 slice under counter toaster oven with bake and toasting capabilities.
No Oven Heat But Toaster Works Fine
My toaster oven will toast. I can see both heat elements working when toasting. The light come on and stays on.
My problem is when I turn on the Oven, say to 350 degrees, the Oven will not heat up. The light flickers and will not stay permanently on.
Is this a fixable issue so I can get my Oven back to working?
Add a comment
1 Answer
Most Helpful Answer
@bettstop could be your selector switch or your thermostat. Use this guide Black and Decker Toast R Oven Knobs Replacement - iFixit Repair Guide to get a good visual on the switch. Post some good images of those with your QUESTION. That might allow us to direct you how to test the switches Black and Decker Toast R Oven Knobs Replacement - iFixit Repair Guide
Score 1
Add a comment
Add your answer
Elizabeth Top will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 29
All Time: 1,172
