Repair guide, disassembly, and troubleshooting information for the Logitech MX Master 3S wireless mouse. Released in 2022 and identified by model number MR0077.
Logitech MX Master 3S get wet!
Logitech MX Master 3S get wet and stop working. I have disassembled few times, used electronic cleaner for all boards but no success. Charging light always red regardless how long I am charging. What to do?
Score 1
2 Comments
Thanks for suggestions. I did everything: remove all boards completely, cleaned all visible spots that possibly from water. But I have used CRC brand QD Electronic Cleaner. My concern about lithium battery. Its label says 4.2V, but can be charged up to 4.1V only.
Do I need to replace it? Again, regardless how long I am charging - red light (mouse indicator) always present, not green.
by
Igor Vysoc that voltage is ok. But it is not enough to test the voltage to prove that the battery is okay. If it got wet etc, I would replace it as well.
by
Add a comment
Most Helpful Answer
Igor Vysoc you did not tell us if you removed those boards. If you did, post some pictures of those with your QUESTION. Adding images to an existing question
It is always best to remove and to properly clean everything with some high grade isopropyl alcohol. For a proper cleaning, use this guide. Repairing iPhone Liquid Damage It was written for a Apple iPhone 3G but it is still pertinent to your mouse as well. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once properly cleaned, REPLACE THE BATTERY and reassemble to re-evaluate.
iPhone Image
Guide
Difficulty:
Difficult
1 - 2 hours
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Score 3
Add a comment
Hi everyone I made the same mistake. My left button got stuck and I didn’t want to open the mouse and I tried with contact spray to spray in the holes of the left click. But then the mouse stopped working. The red light is blinking, then I open the mouse there is no visible issue. I disconnect the battery tried to connect directly with cable but still got the red light and no option to connect with any device.
2 Comments:
I have the same and exact scenario as you, my left button out of nowhere just stopped working. I tried to clean with a contact cleaner, when I switched it on again - then the red light is blinking. This is a very frustrating issue, and it's seems like the issue is repeatable with others. This must be something to do with there firmware and this is not a hardware issue - maybe, just maybe, Logitech is doing this on purpose.
Have you tried to fix it? I love this mouse, if it doesn't work anymore I have no choice but to buy again.
by
i got the same issue with the same rational, any solution got working with you
by
Add a comment
Add your answer
Igor Vysoc will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 70
All Time: 3,198
