Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
Problem after update to ios 16
hello everyone after updating to ios 16 my screen stopped working properly I tried to install ios 15 but the phone after the attempt would not turn on all the time glowing logo apple , it was lying like this all night and this morning I managed to install ios 16 but unfortunately there is still a problem with the screen , I know that the screen works because on ios 15.6.1 it worked normally for me only after the update it broke in what is the problem? i also do not have original screen. There also is some error messege in 3utools the error is panic cpu x caller crash reason problem conecting cpu and peripherals if somone knows thanks for answer.
Score 3
8 Comments
iOS 16 kills all aftermarket screens with iPhone 12s and up
by
@aiman101 so iPhone series below 12 are good to go?
by
No mine is messed up iPhone 11
by
My iphone11 stopped working completely. I was resolving issue with support and now my phone is brick. It doesn't power up at all.
by
It all works now with latest ios16 update.
by
Show 3 more comments
Add a comment
Chosen Solution
Replacement screens will no longer work on IOS 16, either black screen or touch issue, confirmed with iPhone 13 mini this day, worked great, but after the IOS 16 update the touch stopped working.
Score 5
4 Comments:
This has happened to my daughters iPhone 11,she did the IOS 16 update last night and now her touch dosnt work,it’s a replacement screen too,any idea how to fix it please?
by
Had my 12PM screen replaced 3 months ago, did the ios16 update yesterday morning, my screen went black. I had no idea you had to actually go to an apple repair shop to get an actual apple screen until AFTER i paid $220 to get my screen repaired 3 months ago. Had to go yesterday to an authorized Apple repair shop and pay $330 and now my phone works like new.
by
The only solution is Apple will fix it through a update, or get an original screen, it's just another way for Apple to milk more money from their customers, and to symbolize third party repairs as something bad.
by
The fix is to have your phone updated before you replace your screen. Verify you have used a knowledgeable tech to replace it. Afterwords use the same tech to repair your software. Apple is and always has been a proprietary company. It doesn’t mean there are no work around.
by
Add a comment
Either a corrupt download or apple has cocked up the update again, which they do all the time. Try a hard reset first. If you have your data backed up try a restore. If not try and install it again with 3u tools. If none of that works you may have to wait until apple fixes the problem.
Score 4
7 Comments:
I installed ios 15.7 and everything works normally I tried ios 16 again but it still didn't work properly for now I will go back to 15.7 and wait for another update
by
@swdrbb any update about this ? do you manage to fix the issue by back to 15.7 ?
by
@frisha_frish93 I installed ios 15.7 and it works normally
by
This exact thing happened to me I am on iOS 15.7 right now. I can’t go to iOS 16 without my screen going completely black
by
What website could I use to go back to iOS 15.7?
by
Show 2 more comments
Add a comment
I have ios 16 but the problem is that after the update the screen stopped working properly and in 3utools show error panic cpu x caller crash reason problem conecting cpu and peripherals
Score 2
1 Comment:
Try hard reset first
by
Add a comment
Apple users should now start seeing the iOS 16 update on their iPhones. Just go to Settings> General> Software update and it should reflect. In our case, we saw an update for iOS 15.7 first, and then below that an option to upgrade to iOS 16. Apple's iOS 16 update is adding a new passkey feature.
Hope You Find This Useful,
Peter
Add a comment
im using iphone 11, right after installing ios16 . my iphone screen become 'ghost screen' . i can't use my iphone preperly the screen is moving and dragging everywhere . i was reset my phone more than 3 times . i have change the screen before with the third party provider. Is that the reason of this issue ? any idea to fix this ? do i need to go to apple to change original iphone screen ?
2 Comments:
you need to install an older version of ios that is 15.7 and it will work
by
I have managed to downgrade to 15.7 using 3uTools. Now the touch screen works.
Step 1: Place the phone in DFU mode
Step 2: Access "Easy flash" menu of 3uTools
Keep in mind that this method will erase everything on your phone.
by
Add a comment
Add your answer
Jakub will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 16
All Time: 18,877
