Up to 20% off select tools
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
How to charging point
how to fix charging pin
Score 1
Add a comment
Chosen Solution
Just buy a new charge port, comes as a complete board. Just open the phone and swap it over. No soldering involved.
Score 1
Add a comment
Most Helpful Answer
Hi
Unfortunately you can’t really fix a connectors pins without replacing the whole connector as they are very small and it could be too far gone
You will have to solder on a new one to fix the issue or replace the board/cable if it’s attached to one
If you post a picture of the inside using this amazing guide I can confirm that for you as it could just need cleaned rather than replaced:-)
Adding images to an existing question
If you need any help let me know
Hopefully this helps
Any questions please ask
Score 1
Add a comment
Add your answer
tumo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 566
