Up to 20% off select tools
Chinese brand phone, runs AndroidOne, pentalobe front screws
How do charging Jack replacement
How do I charging Jack replace
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi Kaif,
Unfortunately iFixit does not yet have a guide for your phone, but fortunately they're not the only ones dedicated to do-it-yourself repair. There's a French site called SOSav that has a guide to replacing the charging port assembly on your phone. Here you go.
Charge connector Xiaomi Mi A1 repair - Free guide - SOSav
The parts seem to be readily available; here's a couple of the first ones I came across.
Amazon.com: MMOBIEL Dock Connector Compatible with Xiaomi Mi A1 2017 - Charging Port - Headphone Port / Microphone Replacement - Type C - Incl. Screwdrivers : Cell Phones & Accessories
for Xiaomi Mi A1 Mi 5X USB Charger Port Dock Connector PCB Board Ribbon Flex Cable + Headphone Jack Audio Earphone Charging Port
Good luck with your repair! Be sure to ask if you need help with it.
Score 1
Add a comment
Add your answer
Kaif Nandan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 353
