Defects in graphics screen
I have a macbook pro 15 2009 with nvidia 9400M as graphic processor unit… it is someway to fix the issues with the graphics… the laptop is completely useless right now…
Thanks so much!
Thanks so much!
Hi
There are 2ways you can do this
1)replace the logic board
2)replace the GPU on the logic board(not recommended)
Sadly these are your only options for fixing a faulty gpu
Hopefully this helps
Any questions please ask
Are you sure the issue is the GPU and not the display? Have you plugged in an external display in to see if the image on it is clean. If it is then the issue is the display not the GPU logic.
You were right! I try to disamble all the screen and reforce the screen cable to motherboard and now it is working perfect!
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 278
