The smaller, economical version of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
My phone is not charging
My s10e is not charging. Each time I I plug it in it shows a notification saying that the cable is not recognised. I have tried rebooting the device and using a different cable and power source. Should I replace the battery?
Score 2
Add a comment
Most Helpful Answer
Ibrahim Hanif make sure that you do have a good cable and you could try an original. If that does not work you will have to check the power port. Clean it with a couple of drops of isopropyl Alcohol and some puffs of compressed air or equivalent. If that does not change anything your next step would be to replace the charging board.
A bad battery would not give you that type of error message. If you take your phone apart its always a good idea to change it anyway.
Score 1
Add a comment
Probably damaged charge port,
Add a comment
Add your answer
Ibrahim Hanif will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 497
