There are various series of DeLonghi ESAM coffee machines. On the bottom of the machine, you will usually find a sticker with the model designation ESAM 3xxx, ESAM 5xxx, or ESAM 6xxx.
Delonghi Caffe Corso Flashing Water Tank Error
Hello, my Caffe Corso worked fine until a few weeks ago when it stopped making coffee. I took the entire thing apart water pipes, pump, valve etc. and found the primary issue - a huge rock of limescale clogging one of the smaller pipes - and removed it. Water now flows, however, only for circa 10 seconds and suddenly it cuts out with the water tank light flashing. I can try again and it will work but again, only for circa 10 seconds. Does anyone have any ideas aside from the usual one of turning the steam nob because this only works for 10 seconds too. For the same reason, it cannot be properly descaled, although I've manually ran this. Thanks!
Score 1
1 Comment:
Did this tips helped out...I also have this problem
by
Add a comment
1 Answer
Have a look for the flowmeter. There is a guide for the ECAM series, the flowmeter for ESAM is the same.
Replace/revise DeLonghi ECAM Series flow meter
(In German, use Google translate)
The test mode could bei helpful:
DeLonghi ESAM xxxx - Test Mode
And: there is a "finger" on the rear side of the drip tray. If it is broken, the machine does not "feel" the closed tray.
2nd and: worst case: a clogged heater...
DeLonghi ESAM Family Image
Guide
Difficulty:
Moderate
DeLonghi ECAM Series Replace/revise flow meter Image
Guide
Difficulty:
Moderate
Add a comment
Add your answer
Lewis Bateman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 1,745
