Up to 20% off select tools
The Sony ICF-7600D is a compact, microprocessor-controlled, dual conversion portable receiver first produced in 1983. This model is the European version of the ICF-2002 model.
How do I open the case?
My Sony Radio ICF 7600D has stopped working and I want to open it up to see what may be wrong with it. I have taken out 4 screws, but cannot get the case to open up fully. Anyone have any ideas?
Score 4
3 Comments
Thank you oldturkey03. Great advice and I have managed to get my radio working again.
by Share
That is perfect, great job:-) thanks for accepting my answer.
by Share
Thanks. I was stuck. Thanks. I was able to open and lock the "Rod" into place
by Share
Add a comment
1 Answer
Chosen Solution
Try this."To open my ICF-7600D loosen (and remove) the two black screws on the L and R top and the two brass screws (one in each battery compartment). Then, because of a lip on the right lower side, open the backside turning it like a page from left to right.Furthermore, like with laptops a strong thumbnail is an indispensable asset for loosening latches." Once you have it open, you can get the schematic from here and a bit more of a service manual from here Hope this helps, good luck.
Score 4
1 Comment:
+1 nice schematic
by Share
Add a comment
Add your answer
rjnleonard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 42
All Time: 4,168
