Repair guides, disassembly, and troubleshooting information for the 6th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in March 2018. Identified by model number A1893. Features a 9.7" Retina display and 64-bit A10 Fusion chip.
Replaced digitizer, LCD not working the same
I replaced the digitizer on an iPad 6 (that was working 100% aside from the shattered screen) and now the LCD is not cooperating. Blocks of grey/white/black along the top edge. It lights up; it makes the sounds when plugged in, there was even a brief moment when though half the screen was giving white lines/blocks, I even saw the Apple logo. I’ve tried reseating the connector cable, I’ve placed a card under the battery before disconnecting the LCD, I tried the hard reset…. No luck.
The power button works; the home button works. Everything else works as it should
Can anybody confirm if the LCD really is beyond repair (somehow I damaged it in the extraction?) or if it’s something else. The prongs all look good, nothings shorted… I’m at a loss.
Score 1
Add a comment
That's a common symptom of a cracked LCD. Apple uses that black epoxy on the corners where the LCD screws go which makes removing it it a delicate process. The LCD was most likely flexed past its tolerance point and cracked. Replacing it should get the iPad back to normal.
Add a comment
Hi Robert.
I changed the display LCD and look it.
The IPAD reboots alone each 3 seconds and the display appears like in the video.
Is IPAD 2018 6gen
2 Comments:
Ah. When I have seen this across multiple LCDs on the same device it typically points to the connector for the LCD on the logic board being damaged or components near it knocked loose.
by
yeah Robert the new LCD is Broken. Now with a new LCD is working
by
Add a comment
Add your answer
Jade t will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 551
