screen is full black
screen is black but i can recieve the call by guess.
The LCD layer of the screen is most likely cracked which will result in no image being displayed on the screen. You will most likely need a new screen to resolve the issue. You can also always check the connection from the screen to the board as in some rare cases the flex cable can become slightly disconnected. Liquid damage can also cause this symptom. Just mentioning in case the device was near liquid recently.
If your screen is completely black but you can still receive calls, there are a few troubleshooting steps you can try:
If none of these solutions resolve the issue, it's possible that there's a hardware problem with your device's screen
Screen belat I am answer call tuch is ok
Display Tuch is ok
so if your phone showing black but you feel THAT ITS ALIVE LIKE VIBRATING OR screen is a lil glowing that means you have a soft brick. ok now press power+vol up button then enter recovery mode then you recover from there.
Well black screen but still receives calls, it means the phone is powered on, but the display isn't working properly. Well you can do is check your phone for any physical damage on your phone screen and try to Force Restart the Phone if the screen is still remain full black it means Software crash or boot loop without full failure.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 821
Screen change phone m30 samsung
by Sunil Agarwal Share
Screen is black nothing I can see
by gadgets world Share
My phone screen is getting black day by day. In starting it is very small gradually increasing
by SURYMANI KUMAR Share
