Device repair and information for the Vizio D-series 50" LED television with model number D50n-E1.
Why is my remote not working?
I own a Vizio 50 inch model V 505-G9, purchased at Sam's Club in July 2020. Vizio sent me a new remote but the tv will not respond. The only way I can turn on the tv is manually at the back. Remote not functional.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Edward Reinert since this is a new factory remote we can rule it out (hopefully) and I am sure it is not a user error. New battery and all I assume. The only thing then is the IR sensor on your TV. Make sure it is not obstructed and make sure that the plastic cover in front of it is clean. If all that checks out it is possible that you will need a new IR board. We would need to know your exact model number and you will have to remove the back cover tec. for that. Of course, check to see if it is still under warranty etc. If so let them fix it to their cost, not yours.
Score 3
Add a comment
Add your answer
Edward Reinert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 288
