How to replace front inner tube on alpha hover 1
How do I replace the front inner tube of my alpha hover 1
First you haave to take the wheel off. Then you need to take one side of the tire off the rim. Use the appropriate tool, not a screwdriver. Then pull the tire out. Start at the valve stem. Then put some air in the replacement, barely enough to keep its form. Then put it into the tire. Again, start at the valve stem. Using the appropriate tool, put the tire back on the rim. Put some air into it and insure the tire seals around the rime evenly on both sides. Then air it to the listed pressure.
Replace wheel onto scooter.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 62
All Time: 1,366
