The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
How do I replace the instrument cluster lights.
I have been trying to replace my instrument cluster lights. I have watched many videos and looked all over trying to find out how for my specific vehicle. I can remove the cluster but then the circuit board has one light bulb on it that indicates the head lights. Please help.
1 Comment:
Hi,
What is the specific Altima model and year of your vehicle?
Have you checked for small smd LEDs on the board?
by
Add a comment
normally the bulbs are very small and they are socketed.
If you have the cluster out, you should be able to drill down, removing the PCBs till you can see and remove/replace the bulbs.
Add a comment
I just ran into this issue as well I tore the entire unit apart on my 2006 nissan altima s with 2.5l to find out the lights are non serviceable led bulbs soldered to the cluster board.
Add a comment
Add your answer
John Lemon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 886
