Repair information for the Creality Ender 3 Pro--an upgraded version of the Ender 3 3D printer, made by Creality. Released in September of 2018. Model number: Ender 3 Pro.
Motors are no longer functioning
My 3D printer is no longer moving and makes a loud clunk noise when it attempts to move, this happened after I attempted to download south leveling firmware from the creality website, I’ve tried flashing it, and it no longer flashes, I’ve attempted to do all of the fixes presented, like the old firmware on a new SD card in plugging it and plugging it back in, but nothings working. How do I fix this issue
Add a comment
1 Answer
Sounds like a corrupted or wrong firmware . First you have do determine if your Ender came with the new 4.x.x boards( you have to take the cover off and you will see it printed on the board) which are now 32bit with a bootloader pre-installed . If it does , then you can use the SD card to flash the firmware. It may fail few times but eventually it will flash. Re-formatting, trying different SD cards and different storage sizes are few things you can try. However, if you have an original Ender with 1.x.x boards then the flashing process is bit more complicated because these boards are only 8 bit with no bootloader installed. If you search for Teaching tech, Thomas Sanladerer , or CHEP on YouTube. They have plenty of detail and step by step videos for the Ender 3 and the flashing process. Good luck.
Add a comment
Add your answer
Larc McGee will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 23
All Time: 546
