Up to 20% off select tools
Repair guides for DJI's 3rd lightweight mini drone. The DJI Mini 3 Pro was released in May 2022. Model number: CP.MA.00000488.01.
GPS module not detected
After a crash, the drone does not detect its gps / IMU module.
There is no apparent damage on the drone, but it can’t detect gps anymore, the gimbal doesn’t move, and the IMU reports an error.
With that, the drone motors won’t start.
Everything else works. Still can take pictures, make films, etc.
Could a gps/IMU module have been broken at impact, but not no physical damage in the outer shell?
2 Comments:
Hi there. Trying to calibrate compass or IMU simply get stuck and does not work.
I was thinking of opening it to see it it’s a loose cable, but wanted to get a sense if it’s a thing or not…
by Share
No crash drone tower sight fly good fly next time fly no fly
by Share
Add a comment
Yes. It could be as simple as a connector becoming loose or a quick calibration. There was some laptop software that would do a complete calibration. You could get it from DJI website.
I have had to replace broken components but first I would do a gps and IMU calibration.
Add a comment
If calibrating the drone does not restore the GPS, try replacing the module. I made a detailed video tutorial here DJI Mini 3 Pro GPS Module Replacement
Add a comment
Man I have the same issue, but I open the Drone and discovery the flat cable of gps are broken.
Just buy one in alyexpress and be happy.
In YouTube have a video whit disassemble mini 3.
Add a comment
Add your answer
feliperosacunha will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 43
All Time: 3,448
