The Logitech UE Boom 2 is a waterproof, portable Bluetooth speaker known for its 360 degree sound. The Boom 2 comes in a multitude of vibrant colors and patterns.
Why my speaker is not powered?
Hello guys,
First of all I'm not an english native speaker so sorry for the mistakes.
Couples year ago my UE BOOM 2 fell into sea water and it didn't work anymore, when I get home I just put it in rice and and it stayed in for a very long time. 2 days ago I tried to charge it (there is the blinking white light) and to turn it on and it worked for like 30 seconds I was able to put music and then it turned off saying that there was no more battery. Basically every time I plug it and I wait a bit I can turn it on during few seconds. I managed to unplug the battery (Li-ion 3.6V 3200mAh) and tested it with a voltmeter. It says that the battery voltage is 4V, then I concluded that the battery was fine and there was an issue with the powering of the speaker. My questions are : have you ever seen something like this ? Do you have any advices about the pieces I should test or replace ? Does anyone know how to fix it ?
Thank you
Add a comment
1 Answer
You should look at the PCB inside of the speaker as well as any connected terminals. Since it fell into Sea water I suspect that there is major corrosion going on despite the rice.
Add a comment
Add your answer
Eliott Guira will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 275
