Up to 20% off select tools
The HP Deskjet 2600 is a compact all-in-one inkjet printer series released by Hewlett-Packard in April 2017.
Refuses to print please help
It refuses to print. I tried everything I can think of please help
2 Comments
What have you tried? "I tried everything I can think of. . ." does not help us help you. We need a list of what you have tried and how as in what did you actually do.
For example did you run "HP Print and Scan Doctor for Windows"?
And is HP Deskjet 2600 the correct model number? HP lists models 2600/2675/2676/2677/2678. Which is yours?
by Share
check everything I can think of nothing works, paper comes through as if printing but blank
by Share
Add a comment
1 Answer
Chosen Solution
Hi
Have you tried the following
Connecting it to WiFi
Making sure ALL colours have ink left as if one runs out it won’t print
Make sure the paper door is closed properly
Try connecting though a usb cable
Make sure it doesn’t need a firmware update
If none of the above works let me know and we can further investigate
Score 3
5 Comments:
It doesn’t print just printing blank sheets
by Share
@valeriewhit3317
What is the result if you print a diagnostic page?
See p.88 of the user manual
by Share
No imprime solo imprimiendo hojas en blanco.
by Share
@jayeff imprime en blaco. los cartuchos son nuevos
by Share
Les cartouches sont neuves mais ,e signal couleur clignote et l
́impression ne fonctionne pas
by Share
Add a comment
Add your answer
grossjenny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 41
All Time: 1,502
