The Lexmark T650 and X652 are part of a range of discontinued monochrome laser printers that are built around the same standard set of parts.
ink very light on paper
new carrtraigr ink light
Add a comment
Chosen Solution
The Lexmark T650 series does not use corona wires. Some possible causes of light images are:
a) The darkness is adjustable - on the printer select: menu : settings : quality menu : toner darkness. A larger number produces a darker image.
b) The toner cartridge might be empty. If this is the case, shaking these cartridges can reposition enough toner to provide a short term quality improvement.
c) Light images may be caused by an old OPC (Optical Photo Conductor) roller that is built into the disposable toner cartridge.
Score 2
Add a comment
Laser printers use a corona wire to transfer the ink dust to the paper electrostatically. A thin image often is a failing corona circuit or dirty wire.
How Laser Printers Work
Add a comment
Add your answer
maureen kavanagh will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 26
All Time: 524
