Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
Is this printer work past Catalina?
I have had this printer for 10 years and I have been very happy with it over the years, but my Mac is aging and I may need to upgrade, while keeping my trusty 2014 Retina in service as well. Part of the reason I have kept this computer in service as long as I have is my mono laser. My color laser doesn't have an issue as I just got it and it's a current model with Catalina support (bravo Lexmark) and will carry over to a new Mac well, but my monochrome laser is kind of a question. While my color laser does mono printing, it isn't proper sharp mono. It is gradient based black output where it only uses the black toner and doesn't deploy the CMY toners. It's still sharp, but it doesn't print like a monochrome only laser does. The mono output from the color Lexmark is fine, but there are times I want the sharpness and low CPP of a pure mono laser.
Has anyone run these in Big Sur and Monterey? If you have, are there any problems I should be aware of?
Score 1
Add a comment
1 Answer
Chosen Solution
@nick I don't have that printer personally, so I can't test to verify 100%, but HP states that it supports MacOS Monterey (which I'm currently using on this computer). Latest driver release was Jan. 27th, this year.
Score 2
3 Comments:
My 2014 Retina stops at Big Sur, so I can run one more release and that's it. Once Big Sur is dead, I'm stuck.
by
@nick I have the same with a 2013 Air. It handles Big Sur alright, but that's it :/
by
@geirandersen I'm holding out on the Big Sur upgrade until I need it, due to HW age plus Lexmark still supports Catalina. Why change until I have to?
I was actually questioning if I needed a OS upgrade getting that Lexmark lol.
by
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 307
