Why my laptop is not opening
Why Laptop is not opening, i press a power button many times but didn't show anything
There are many reasons.
1.Short Circuit. Due to a short circuit, you maybe need to change your motherboard. Maybe only
2.Loose cables or disconnected. Note: a laptop won't work until you connect the fan
These are the reasons I could think of hope it helps you
BY AADHITHYA MATHAN
5TH STANDARD
CHAITANYA TECHNO SCHOOL
الجهاز ليش لهو اي اشاره فقط ضوء شاحن البطاريه
الجهاز ليس لهو اي اشاره فقط ضوء شاحن
Remove the battery (if removable), hold power for 30 seconds, reinsert and try. Check if the screen is the issue — look for a faint display or connect an external monitor. Try a hard reset by holding power + specific keys (varies by brand). If all fails, the issue may be hardware-related — RAM, motherboard, or display — and needs a technician.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 391
Hi
Does the laptop show that it is charging when you connect the charger?
by jayeff
Yes, it is charging but the laptop is not opening
by Sachin Goswami
