The Philips Sonicare FlexCare HX6930 electronic toothbrush is manufactured by Philips and was released in 2007. Five different modes, designed to clean teeth more efficiently.
Replacement battery for HX9120
I'm looking to replace the battery in my Sonicare FlexCare HX9120.
Do you have a replacement battery for this model?
Thank you for your time,
Richard
5 Comments
I found out this battery won't fit my HX9120 Phillips Sonicare, it requires a Sony P/N 4235 010 32899. Unfortunately, I haven't been able to locate this battery anywhere.
by
rmwrench have you determined what the differences are? Size, contact location ? Is this the model where the battery contacts are offset or are they coming from the center?
by
Hi oldturkey03 I don't know the size of the battery I need; all I know is it's longer and smaller in diameter then the one suggested that would work which it doesn't, this is the Item code: IF389-000-2 of the battery that won't fit/work. The part number off the battery in my unit is all I have to go on and up to this date I haven't been able to find a replacement battery any where.
by
As far as I can tell the battery contacts are off set.
by
I am going through this now as well. As far as I can tell, it doesn't look offset. If I get another battery, I just want to make sure it fits. It looks like an AA battery. The lead maybe too wide so it not fit into the hole. I am thinking I could take off the old leads from the bad battery and use it on the new battery. Solder it in so to speak. It is weird that you cannot find a Sony replacement battery for this one.
by
Add a comment
1 Answer
Most Helpful Answer
Yes and a guide on how to do it, look here
Score 1
4 Comments:
@rmwrench
This is the equivalent to the sony:
https://toothbrushbattery.com/guides/phi... I'm not able to say which of the batteries on iFixit are correct if that one isn't. I have no involvement with iFixit business function but I expect an answer will be along shortly.
by
Are you certain of your information? I've now found 3 references that say seemingly this IS the correct replacement. I've alsorefferredd your comment to iFixit.
by
What I did to find several candidates was search for sony 4235 010 32899 substitute, the video I posted in my answer state if the pins are offset to insert at an angle. I can't check that for veracity, unfortunately, but you can search for other substitute cells.
by
Add a comment
Add your answer
rmwrench will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 43
All Time: 2,251
