Also known as Lenovo IdeaPad 5i.
Which screws where on back cover?
Several of my screws have fallen out of the back cover, a common problem with the Lenovo Ideapad. I purchased a replacement set of screws however, it did not come with any instructions, just a bag full of screws. I found the hardware maintenance manual however it just tells me that I will need five - M2 x L8.5 and four - M2 x L5.5 screws and no information is given as to which ones go where. It would normally have been an easy swap but because some of the screws are missing I don't have a reference.
Score 1
Add a comment
Colleen Deis now I am confused, but that could be related to my age. You know that the screws you need are
five - M2 x L8.5
four - M2 x L5.5
I now assume they just threw those screws in a bag (as usual). Get a pair of calipers and measure the outside diameter of the screws on the threaded part, not the head of the screw etc. The ones you need are 2 millimeter diameter and 8.5 millimeter and 5.5 millimeter respectively. Looks like the manual shows what the screws are supposed to look like (Torx head).
1 Comment:
five - M2 x L8.5 goes in the middle and rear of the botton cover.
four - M2 x L5.5 goes in the front where the 4 holes are in the bottom panel.
by
Add a comment
The 4 shorter screws go into the four holes in the front. The 5 screws go in the middle and rear of the bottom panel.
Add a comment
Add your answer
Colleen Deis will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 51
All Time: 3,450
