Up to 20% off select tools
The Oculus Quest is the first standalone virtual reality headset that supports 6DOF tracking with cameras located on the headset itself. The Oculus Quest headset was released in May 2019 in 64 GB and 128 GB models.
Only my right controller
My left controller says it’s sleeping and to press a button to wake it up but it doesn’t work so I stopped playing it for a while and it started to work but when I move my hand to fast it stops working how do I fix it
Score 1
Add a comment
1 Answer
a not-properly-placed battery can cause trouble. Remove and reseat the batteries in your Oculus controller. Then check the battery levels and replace the batteries if they're low. but In some cases, it is the software glitches.
1 Comment:
thank you, well try
by Share
Add a comment
Add your answer
Isis jiles will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 23
All Time: 600
